MIRROR MAGE" CRIT BUILD
Poster un nouveau sujet   Répondre au sujet    heroquest remaster Index du Forum -> Edition 2011-2012-2013 -> Le Mage du Miroir
jensenbreck
Point(s): 134
Moyenne de points: 1,35
MessagePosté le: Mer 20 Déc - 15:49 (2017)    Sujet du message: MIRROR MAGE" CRIT BUILD Répondre en citant
Hello,
The idea behind this build should be obvious, stacked to cooldown on teleport and mirror image so you can spawn as many damaging copies of yourself as you can. Focus on big spells Like meteor and hydra to maximize the copies damage
This also assumes that the mirror images will be spun by the mirror image of the mirror image damage rune. I think it's a fairly safe bet, given that WD zombie dogs function this way.
Gear would mostly focus on + crit, naturally
Thoughts? improvements?
Please help.
Thanks!
I did not find the right solution from the Internet.
References:
https://us.battle.net/forums/en/d3/topic/4079842869
B2B Online Campaign Examples
MessagePosté le: Mer 20 Déc - 15:49 (2017)    Sujet du message: Publicité
Poster un nouveau sujet   Répondre au sujet    heroquest remaster Index du Forum -> Edition 2011-2012-2013 -> Le Mage du Miroir Toutes les heures sont au format GMT + 2 Heures
